Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
Resolved Resolved by bhouston!
Ez-bv 4 And Power Adaptor
Ez-Bv 4 And Power Adaptor
I bought the EZ-Bv 4 for two weeks ago! It is amazing and very good stuff:)
Actually, I want to use that to build my human robotic. Therefore, I have few questions would like to ask!
Would anyone can help me?
Q1 : Can I use this Adaptor for EZ-Bv 4? Q2 : EZ-Bv 4 can support several pieces of motor servo (refer to the attached picture)? Q3 : Will "EZ-Bv 4" damaged by the 12v external power adaptor of Huge servo Motor? (Because I will use it to control all servos at the same time!)
#17
Thanks for all information!
Dear Bhouston,
Could you please share a photo of the Instruction Diagram for my ref?
Thanks a lot:)
#18
@rickymahk2013, Sorry I didn't get back to you sooner. I don't have a photo of how to do this but it is quite simple. Connect your battery power into a bus bar that has positive on one side and negative on the other, connect all your servo and motor power to this bar.Also connect a ground (negative) wire from either your batteries or the bus bar to the negative pin on the EZB v4. Connect all of the servo/motor signal wires to the easy builder.
Hope that helps you.
#19
Dear bhouston,
Anyway, thank you for your great help:) It is useful for me!
