Graphy icon Graphy — Plot live data with ControlCommand scripts: multi-series charts, many chart types, legend toggle, add/remove series, export graph data to CSV Try it →
Ez-b V4 Won't Connect To Wifi
Ez-B V4 Won't Connect To Wifi
Really hope someone can help.
I am trying to connect my EZ-B v4 to my laptop but having no luck so far. In brief, the v4 is found on my available network list, but when I click "connect" it comes up with the following...
I run the troubleshooter and the message I get is...
I have AVG antivirus installed and have tried to connect the v4 with AVG enabled and disabled, still no joy.
Laptop specs. HP650 notebook, with Windows 7 home premium 64-bit, with 6GB RAM and 320GB HDD.
Please help stress
Thanks.
#18
The blue (WP mode) or green (Client mode) will only stop flashing when you connect via ARC.... so solid leds mean you are connected within ARC....
#19
@Steve.gibbs5 I think you may have typed in capital i's instead of ones in the 192.168.1.1 address.
#20
Same thing with the colon too.
#21
your ip address looks wierd. the last should be one.one but in numbers. it looks like it is lower case L.lower case L, or upper case i.upper case i.
192.168.1.1
sorry, I see that you saw that already. I will step out again.
#22
When I tried on my android ... my android gave me the address 192.168.1.2 for my ezb4 not 192.168.1.1 Check your connection on your iPhone to see if the address is different....
#23
Not a problem. Not sure why it com came out like that but I confirmed that I did do it right again.
I'm gonna cry if I don't get this sorted soon. Been at it now for nearly 5 hours now. stress
#24
I could not connect either with my android... using 192.168.1.1 or 192.168.1.2 both would not bring up the ezb4 webserver.... Went back to my pc and it worked no problem.... Hmmmm
