MPU9150 Accelerometer, Gyro, Temperature, Compass icon MPU9150 Accelerometer, Gyro, Temperature, Compass — MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand. Try it →
Ez-B Iotiny Random Servo Jumps/Activity?
Hello Everyone,
I have an EZB LoTiny (such a great little device) set up with 7 ez-robot HDD servos.
The problem I am having problem is with random servos activating, moving anywhere from 1 to 180 degrees. This will happen when the board is powered up and not connected to WIFI and also when it IS connected to WiFi and to ARC.
Once connected to ARC and the servos are moved with either autopoistion or any servo control the servos will act normal and the problem does not come back again until repowered again.
I am using a voltage supply @ 6.5 volts.
I have a couple of EZ-B v4/2 that work without any issues.
Any thoughts would be appreciated or ways of testing?
Sorry, I thought you meant you had used then in other setups
