Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
Hello all, I think I am having the same issue. I have been trying to use the Sure Compass module. With it completely connected to the Ez-B.it works fine for about 20 seconds and the all the lights go out on the Ez-B and the ARC freezes up and so does the Ez-B. I have to CNTL /ALT DEL to get out of the ARC and pull the plug on the Ez-B. start over and the same thing happens. I tried the compass module with an externial power source and had no brownout issue on the Ez-B and no freez up on the Builder. The only problem I had was I thought I had 5v supplying the compass module. I figured out I had more voltage then 5v , when the smoke came out of the compass module. So I have ordered another compass module and will try it agin, with a verified 5v power source.
Netherlands
@airwave1206 How did you connect the compass? I've been trying for weeks now to get the thing working and I keep getting the same problems you have. But if I just have to power it externally, I'll do it the moment I get home.
@DudeIO I not saying this is the fix since my compass module smoked. I took apart a usb car charger and attempted to connect power wires to get the regulated 5v. I have not measured the output of that device since it smoked with the compass module. But if you really think about it, if you have a 5v battery your trying to charge, are you going to use 5v? No, you have to have a higher voltage to get the battery to 5v. I am a automotive tech and the cars do the same thing. The car charges the 12v battery with 14.5v in most cases so they can achieve the 12v charge. Any ways, I connected the SCL and the SDA lines to the Ez-B's I2C port. The 5v and ground to the usb car charger. The compass worked flawlessly for around 2 min unti the smoke let loose. I am going to try this again, but this time I am going to verify the 5v and possable connect the ground to the power source and the EZ-B. I don't know if DJ have suggestions about this? So it's up to you, not saying its going to work or what will happen. So use it at you own risk. It costed me my a $10.00 compass module and a usb car charger. I might try a PC power supply. They are really regulated. Good luck and I will keep posting my findings.
Netherlands
@airwave1206 What I was trying to verify, was that if the EZ-b wasn't able to provide enough power to the compass, it would brown out, so you should power it externaly, which if I understood you correctly, you did. Only with the wrong power supply. So my plan was to just use a 5v regulator and power it of my batteries(2s lipo's).
That's correct most devices need external power , ie not through ezb.
#15
@jstarne1 do think I need to have the grounds tied together from the power source the I2C compass module and the EZ-B? I was wondering if that had anything to do with the untimely release of magic smoke from the compass and the usb power supply. so now only waiting for the Sure compass module to come from China to retest the theory of external power supply.
@budel0 I have tried everything else. it only sounded logical to try an external power source. it was my mistake for not checking the voltage. I am still not sure about the grounds. I don't think it would hurt to have them all connected.
This is L.O.R.A.
