i had so much fun thismorning playing whit jd. untill the batt was empty.so my question is,there are bigger batt, with higher MAH 2200, could there made a connection in jd, to disconnect the batt inside thru a swiths and connect the batt, from outside jd thru a connector.
dont know if there are any with more MAH
howmany amp is the swiths off jd.
