i had so much fun thismorning playing whit jd. untill the batt was empty.so my question is,there are bigger batt, with higher MAH 2200, could there made a connection in jd, to disconnect the batt inside thru a swiths and connect the batt, from outside jd thru a connector.
dont know if there are any with more MAH
Our battery is 1300 mha - but it's a high quality brand that is popular because of a good reputation.
The battery link I posted I can not vouch for.
dj
thats why i wanted to use the same brand but outside.see post #8? for the switsh.
@Nomad... I think DJ was/is trying to point out as well is that he can't be responsible if the battery damages your JD... So maybe it's wiser if you just buy and use another 1300mAh battery from ez robot... No matter which way you go be careful of your wiring....
richard r
ah have 3 spear ones.
Most, if not all, of the battery manufacturers (assemblers) will fudge the mAh a little and the C rating a lot. The mAh rating is usually more reliable but the C rating is not to be trusted.
I think the biggest worry you have with LiPo batteries, as far as damaging your equipment goes, is if it bursts into flames from shoddy manufacture.
zap
thats not a good though.scary.
Yeah, Lipos are one of things, that if you just look at them, they burst into flames, usually so fast you dont have time to get out of the way.
sofar i have no problems with lipos,got 7 in my house. eek
