Interface Builder icon Interface Builder — Create touchscreen robot control panels with buttons, joysticks, sliders, camera views and scripts; multi-page fullscreen UIs for PC and mobile. Try it →
#25
Thanks dude! These are interesting designs. Thinking of using all these designs to make my own gripper.
#26
Heres my idea. Using part of the gripper design that's like the one in the shop, and the beetle like gripper rgordon posted I made this. Parts sized and everything. Comments? Changes? Also need to figure out what material to use.
Aw dude! This is better, way better. Don't worry, I knew my design wasn't that original. Ill play with this idea. Thanks!
#29
Here's my interpretation.
Huh? Huh? Yes I know the gear on one side needs to be offset a little so the teeth link up with the "fingers" straight. This was a quick job. ill do more to it to make it proper in a bit.
Techno pro. I think that looks good.there might be some play in the teeth of the gears. What about a mini servo for each claw. Or "finger". Its just a thought.
#32
@vhs896, That would work but it's just as easy and cheaper do use the geared setup.
@Aameralis Thanks dude! Ill take a look. If you want, you could try do build the whole mechanism that I have shown.
