Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Converting A String To Integer In Ez Scripting
I am using the plug in for the XV-11 Lidar. The output of the plug in an array in which each value is a string that represents the distance at the angle and the signal strength. To use this for control of the robot, I need numbers at these angles. The format is shown in the attached example. How do I parse and convert this in EZ Scripting into an integer?
In C there is the string.split command
https://msdn.microsoft.com/en-us/library/b873y76a(v=vs.110).aspx
and then the string to integer convert.
Is there a way to do this in the EZ scripting?
#33
Download and installed successfully ver13
So this is strange. I opened a new project, installed your Ver13 plugin. Add it to the new project it locks up. I open my own project with your plugin ver13 deleting the lidar plugin and adding the new ver13 plugin and it still locks up.
I then restore my backup ver11 plugin opened my own project with the plugin ver11 all ready add and it works. So I deleted the lidar plugin and re-added it and it locks up.
So I'm not sure way it worked with my project that ver11 was saved in ARC and not able to delete and re-add the same ver11 plugin.
If maybe I I am doing something wrong, I still have teamviewer installed.
Thanks
#34
It is strange. Okay, I will have to wait until tomorrow to try to address. It is hard to know what is going on without a reliable Get Surreal controller on hand. It really has me wondering what is going on. I may connect to your computer tomorrow or Tuesday after I have a chance to look into it more.
#35
Sounds good. Thanks David.
#36
The part I need didn't arrive today. Maybe tomorrow it will be here.
#37
Thanks David, you have my number
#38
The controller arrived. I haven't had time to build it yet as work has been a lot of fun today. I should have something for you tonight still if work calms down.
#40
Well, from the looks of it, I will be working late into the night tonight. I have to find one record in a 35TB database that is causing a process to break. Unfortunately I am the only one in the company that knows this data to the level of detail to resolve the issue. The good thing is that this database is going away in a couple of months, but until then I am trying to make it limp along until decommissioned. Because of this, I now doubt that I will have time to look at this tonight. I did get the Get Surreal controller built and flashed so now it is just finding the issue.
@mstephens_42, is yours locking up now too?
