EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Converting A String To Integer In Ez Scripting
I am using the plug in for the XV-11 Lidar. The output of the plug in an array in which each value is a string that represents the distance at the angle and the signal strength. To use this for control of the robot, I need numbers at these angles. The format is shown in the attached example. How do I parse and convert this in EZ Scripting into an integer?
In C there is the string.split command
https://msdn.microsoft.com/en-us/library/b873y76a(v=vs.110).aspx
and then the string to integer convert.
Is there a way to do this in the EZ scripting?
#25
I just put the latest code out and updated the project.
      private void MainForm_Load(object sender, EventArgs e)
            //button1.Enabled = false;
            loadConfig();
           // EZ_Builder.Scripting.VariableManager.CreateVariableArray("$LIDARDistance", 0, 360);
           // if (Convert.ToBoolean(_cf.STORAGE[ConfigDictionary.chkUseIntensity]))
           // { EZ_Builder.Scripting.VariableManager.CreateVariableArray("$LIDARIntinsity", 0, 360); }
            try {
                if (Convert.ToString(_cf.STORAGE[ConfigDictionary.comportname]).Length > 3)
                    initializecomport();
            catch
                MessageBox.Show("Select the COM port being used by the LIDAR on the config screen.");
            backgroundWorker1_DoWork(null, null);
       private void loadConfig()
            drawline = Convert.ToBoolean(_cf.STORAGE[ConfigDictionary.DrawLines]);
            drawArea = panel1.CreateGraphics();
            string pc = Convert.ToString(_cf.STORAGE[ConfigDictionary.thePenColor]);
            string bc = Convert.ToString(_cf.STORAGE[ConfigDictionary.backgroundcolor]);
            Pen pointpen = new Pen(Color.FromName(pc));
            drawArea.Clear(Color.FromName(bc));
            drawArea.DrawRectangle(pointpen, panel1.Width / 2, panel1.Height / 2, 4, 4);
            drawArea.Dispose();
         private void backgroundWorker1_DoWork(object sender, DoWorkEventArgs e)
           if(Convert.ToBoolean(_cf.STORAGE[ConfigDictionary.chkUseIntensity]))
            {EZ_Builder.Scripting.VariableManager.CreateVariableArray("$LIDARIntensity", 0, 360); }
      private void initializecomport()
            try {
                _serialPort.BaudRate = _baudRate;
                _serialPort.DataBits = _dataBits;
                _serialPort.Handshake = _handshake;
                _serialPort.Parity = _parity;
                _serialPort.PortName = (string)_cf.STORAGE[ConfigDictionary.comportname];
                _serialPort.StopBits = _stopBits;
                _serialPort.ReadBufferSize = Convert.ToInt32(_cf.STORAGE[ConfigDictionary.BufferSizeValue]);
                _serialPort.DataReceived += new SerialDataReceivedEventHandler(_serialPort_DataReceived);
                _serialPort.Open();
                comportInitialized = true;
                //_cf = cf;
            catch(Exception ex)
                MessageBox.Show(ex.Message.ToString());
                MessageBox.Show("COM port not initialized");
This is the portion that initializes the array(s) and also the comp port.
#26
@David, mine also locks ARC up, yesterday was it working, the only this I changed today is updated the latest ARC. Now I can not get it working again.
#27
I forgot to say, I loaded a new project when this happened, I also backup yesterdays plugin. What is funny is both my project's and new project have the latest ARC Version 2016.02.20.00
So with a new project and yesterdays plugin it still lockup. However, using my project and yesterdays plugin it works?
#28
Okay, that would indicate that it is a config setting that isn't set by default. I wish I could duplicate the issue. I also downloaded the latest ARC to make sure it worked with the new version. I can't seem to get it to lockup. I do have an issue with my controller though. My new one should be here Monday so that I can do some testing and debugging.
#29
I just checked your plugin date I am using and it was 2/18/1016 not yesterday, sorry about that. Thanks David.
#30
@Mike and @DJ, I suspect that this release this morning will solve the issue you are seeing. Please let me know. I am hesitant to change the com port 3 default setting until I know if this works for you.
Thanks David
#31
Morning David, it lets me configure the com port and then when I click start lidar it locks up ARC.
Thanks
