Ultrasonic Radar icon Ultrasonic Radar — Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing Try it →
Change Action Name.
Change Action Name.
Simple question.  How do you change an action name after creating it?
Movement Script by Synthiam
Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ).
EZang
no you didn miss it.dj is still working on this.if there's an update in ARC, ARC will flash when you open ARC.means there's an update.
you can check for update manuelly too.
#12   — Edited
Is the beta as good as the release?
The newest release is working fine, don't want to mess things up
You should be fine. If something isn't working correctly just mention it. You would be doing a big service. DJ usually gets major things fixed pretty quickly.
ok, thanks -  I was just wondering why it wasn't called a release
#15
Thanks DJ.  I am so happy to be able to change name.
It makes things easier.
Ellis
