Watson Speech To Text icon Watson Speech To Text — Watson Speech-to-Text ARC plugin: cloud AI transcription with configurable models, selectable VAD (Windows/WebRTC), audio capture and visualization. Try it →
Change Action Name.
Change Action Name.
Simple question.  How do you change an action name after creating it?
Movement Script by Synthiam
Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ).
hi ellis
click on the action you want to remove ,right mous click.
Thanks for the response.  I really want to change the name of an action not a frame.  I am sorry if the post was confusing.  let me know if you need anything.
hi ellis
no your post is correct.i didn read it well.indeed i dont see it eather.
Thanks for your help.  Maybe someone else know's the trick.  I cannot find it either.
You are correct gentlemen, there isn't a way to change the action name but I'm sure if you request it DJ may add it to his list.
Great, that would be a nice change, thanks
Good morn, did I miss the update?
