3-In-1 IMU icon 3-In-1 IMU — EZ-Robot 3-in-1 IMU driver: accelerometer, gyroscope and compass support for motion sensing, orientation tracking and heading/navigation. Try it →
Can't Get Voice Recognition To Work.
Hi All.
I can't figure out why this is not working for me.
It recognizes the command to enable and disable speech ok, so I don't seem to have a microphone issue.
I got it to say a phrase, but only once. I don't think I changed anything to make it stop working.
I can move my servo manually in the vertical servo panel (no problems with the servo), but I can't get it to move by voice, even using the exact phrase in the example (i.e. Servo(D14, 25)), with the servo obviously plugged into D14.
I even tried unplugging and reconnecting the EZ-b.
Can someone help me figure out what's wrong? It'd be nice to be able to see if the EZ-b is recognizing the speech at all.
thanks in advance,
Frank
It is set on USA. Checked that before. Thanks Rich. Get some sleep.
OK, I had a look at your project and it looks like you need to write the proper syntax commands in the Speech Recognition panel. For your commands you just have:
left(255, 1000) for the phrase "Robot Turn Left"
In the command section to the right of the Phrase section you need to identify the proper ports to turn on and off along with anything else you want the EZB to do. Here's a proper syntax example of your Arm servo you have attached to the D1 port turning on and moving to a point:
Servo(D1, 25)
The above example will start up the Arm servo attached to the D1 port and move it to the point 25 position.
To edit these values click on the "gear" icon at the top of the SR control and you'll see the areas you need to edit. IN the left section you enter the phrase you want to say to get a response and just next to it you enter the proper syntax EZ Code functions. You can enter multiple commands by clicking on the pencil icon all the way to the right of the command box and type in as many commands in the proper syntax as you like. This way you can have your robot excite many different things at the same time.
There are many examples in the cloud of this. Open a few to get an idea how it should look.
Also to the extreme left you will see a help section where you can get script help. That section holds all the proper syntax codes you can use and an explanation of how to use them. Rich has a tutorial somewhere on coding. It's a must read for those if us just starting out with this strange and wonderful but easy language.
Good luck, Dave Schulpius
@Dave Left(), Right(), Forward(), Reverse() and Stop() don't need ports defined as they use the movement control panel so whatever is set up in there (ports, scripts etc.) is used.
All of the voice commands in the project are OK and should work so these are not the issue. In fact, they look like they are the default commands that are pre-entered when you add a speech recognition control.
I can't see that anything is wrong with the project however I did just try my Jarvis project (which I know was working) and it doesn't want to pick up my voice either. Can someone else confirm that the latest version of ARC (2013.12.02.00) works with their speech recognition?
Sorry for the bad info. I didn't know that. Thanks for the lesson.
hi.do you need the ez-bv4 controller first to use voice recog.?
@nomad18.08 wrote "hi.do you need the ez-b controller first to use voice recog.?"
You used to. I don't think you do anymore.
so i can use voice recog whithout having the ez-bv4
#16
yes
