Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Resolved Resolved by Athena!
Auto Position Servo Limits
When I use the Horizontal servo window in ARC, I can set a min and max for a servo. However, when I use the Auto Position control panel (Auto Position Robot Skill) I can move the servo beyond those limits.
My question: can I set a min and max for a servo in the Auto Position control panel (or in the Auto Position Robot Skill) so automatic positioning respects those limits? If not, is there somewhere else in the ARC project where servo limits can be enforced for Auto Position?
Thank you.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Horizontal Servo by Synthiam
Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert.
Yes - Auto Position can respect servo limits, but it’s important to understand which limits are being used.
What’s happening
The Horizontal Servo skill has its own per-skill min/max settings, so it will stop there.
But Auto Position works with the servos directly from its own frame values, so it does not automatically inherit the min/max from the Horizontal servo skill.
Where to enforce limits
1) Set global servo limits
Use the global servo limit commands so all skills in the project respect them, including Auto Position:
  • Servo.setMinPositionLimit(port, position)
  • Servo.setMaxPositionLimit(port, position)
Example in JavaScript:
Servo.setMinPositionLimit(d0, 30)
Servo.setMaxPositionLimit(d0, 150)
That sets project-wide limits for that servo port.
2) Set limits in Auto Position frames
You can also keep Auto Position safe by manually constraining the frame positions in the Auto Position configuration.
That means:
  • open Auto Position
  • go to Configuration
  • edit each Frame
  • make sure the servo values stay within your safe range
3) Use servo settings in the skill itself
If you are configuring a servo inside a robot skill, many skills have their own servo configuration via the kebab / menu icon in the skill window. That limit is skill-specific, not always global.
Best practice
If you want all movement in ARC to stay within safe bounds, set the global min/max servo limits first, then build your Auto Position frames inside those limits.
Useful references
Quick question
Are you using standard PWM servos on an EZ-B port, or smart servos like Dynamixel / Feetech? That matters a bit for how the position and safety limits behave in ARC.
If you want, I can also show you the exact JavaScript initialization script to enforce limits automatically when the project connects.
@athena
Set global servo limits like in a init script .
got it thank you
