Justin,
Can you post a snip screen of your endpoint and keys (erase the numbers)
I dont't understand why 2 keys.
#34
I believe the 2 keys is to allow simultaneous queries from 2 devices, which should be enough for a hobbyist or developer.
Is working for me.
@Nomad: does it work for you too ?
@DJ: Thanks
#38
Vision Cognition works great now! Thank you DJ!
However, now the Cognitive Emotion plugin (which I did Update and read the directions and copied in the key and end point correctly) now shows a red X across the picture window where it would normally show the image it reviewed. It still works otherwise, it reads my emotion just fine.
hi it works but he says only i see?
ok he sees the pic now but dont say what it is.
