PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
no grid lines and camera freeze
No Grid Lines And Camera Freeze
i notest the augemented reality doesn work. i also dont see grid lines.when i clicl attach the camera dont move.?
thank you anyone
JD Humanoid by EZ-Robot
Overlay PNG/JPG images in real-time onto detected objects, faces, colors or glyphs using ARC Camera tracking; attach, preview, detach.
#1   — Edited
What version of ARC?
are you running latest augmented reality plugin?
based on the error in your screenshot, looks like the plugin is outdated. It needs to be updated. Always update to latest version when something doesn’t work.
i tested and works well with current ARC and latest plugin.
hi dj
is version 5 the latest augmented plugin?
yes i have that plugin version from this page.
That error in your screenshot cannot be from version 5 of the plugin. That error is attempting to use a method that hasn’t existed in quite a while. You just use the latest ARC and latest plugins.
i have download the pluging from your link.it says indeed something aboud method. i can see the downloadnumber is diff.
Make sure you have the latest version of ARC and latest plugin version. All versions must be the most recent version.
i just dowloaded latest ARC and it stop working.
