TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
extension from ezrobot camera lens to the module
Extension From Ezrobot Camera Lens To The Module
Looking for an extension from the camera lens to the module board.  I was hoping for maybe a foot to 2 foot long maybe a little shorter.  I don’t know what the part is called and was hoping some someone knows where I could get an extension? so I could place the camera lens in a specific spot that is very tight and then connect it back to the main camera module board.
thank you all in advance for your suggestions and help.
Thanks, merne
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
#1   — Edited
You can contact ezrobot at their website for their product. The website is www.ez-robot.com
i doubt that exists. But good luck!
Thanks DJ!
ez-robot is not allowing support questions.
i’m hope someone on this forum my have and answer.   If I new the name of the connector it would help to search the internet.
thanks, merne
Crazy / something like that does exist! Well done ptp
Hi Ptp, thanks very much!
I’ve been busy with other issues and a broken 3D printer.  I know someone would know the parts needed!
thanks again!
