Sketch Pad icon Sketch Pad — Script-driven Sketch Pad for ARC: draw shapes, text, lines and faces via controlCommand() to visualize object locations, paths and robot data. Try it →
#33
@Richard.
Yeah I did try a reboot a couple of times but no joy. I havn't however tried an ARC reinstall. I'll try it now.
Cheers.
#34
Well I just re-installed ARC, no change. It's still using the same default voice as before no matter what voice I select, whether it's Cepstral or the other two default voices, or changing the speech settings. :(
#35
When you said you copied over the Cepstal voice did you just copy the files into their directories or did you use a self extracting windows installer file?
#36
I have done a Windows Easy transfer which contained the .exe file. I installed the voice and Cepstral tools, and entered the activation key. Do you think I have missed something doing it this way?
#37
I am stumped... sounds like it should work Steve... Hmmmm
#38
Yeah, it is a strange one. Like I said, the voice and effect works with Windows and a third party screen reader app, just not with ARC. Weird. confused confused
