Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
#41
Can you refresh the router page that shows all ports in your network ? Then maybe the WiFi board will be identified when you re-power it.
#43
What manual are you talking about ? All I found right now are tutos Arduino and I took all I can from them. The challenge now it to connect ARC to a virtual port forwarding data to the UART wifi IP address.
#45
I got it to connect with router that has password on it but super slow.I tried new router with nothing on it and no password no luck.Reconfigured wifi back to router with password but would not connect,maby i put wrong password in. Tried to redo but would not let me in so took it out of auto mode with arduino and it said OK,but would not let me in(to reconfig card).
So i tried factory reset through arduino and no luck,have done factory reset with arduino before but would not let me now. confused
so time to give up for a little while and clear my head blush
