Screen Recorder icon Screen Recorder — Record your screen to WMV1/WMV2/H263P files with selectable bitrate, save-folder and start/stop controls, creating tutorial or demo video snippets. Try it →
#17
can't wait,glad to see someone still trying
#18
I'm wondering if this will work for the virtual com port: VSPE?
I'll give it a try tomorrow.
#19
I'm also wondering if I shouldn't get a second TLG10UA03 (for the host computer) and run in transparent mode, on an adhoc network, and then bridge maybe? Just throwing out ideas here. Documentation on this thing is rather lacking.
Anyone know where (in English), to get FW updates?
#20
Ok, auto-join solved. Check "Auto Mode Enable" in the www interface, (once they're talking) TCP for a protocol, and SERVER for the mode. You can now disconnect the module from the UART module and power it separately and access it via it's IP. Works a treat.
So I just need a virtual serial port to interface with ARC now and it should all work. I suspect the module's transparency mode options may be the key.
And I can see the UART-USB module being a very useful tool for other projects beyond robotics.
#22
I'm thinking that this, although pricey, will work for the virtual comport: WiSnap
#24
Same. But I need a virtual serial port. I think this will do the trick for the host computer end of things.
