Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
Why Isn't My Servo Working
As the title says. It's an EZ robot micro lever servo. When I try to move it with a script or "H" or "V" servo control... Nothing.
It's not released
Ezb is connected
7.4 LiPo battery is fully charged
Ezb has been power cycled
Doesn't work on different digital ports
It's connected correctly (and always has been)
It worked up until yesterday
It's not under any strain in any way
It's been calibrated correctly (it used to work ok as mentioned above)
Other servos work on the same ports
Wires have freedom of movement
Tried a new project with just a vertical servo control
Moves freely when I turn it by hand (connected or not).
Any ideas?
@DJ.
I take it you havn't seen my showcase then. The speakers (with magnets), battery, some of the internal plastic, and circuitry had all been removed, and speakers placed in to the robot body (as seen in my "making of" video in the project showcase). It's just an empty lightweight plastic shell now with the exception of two LED's, two sound sensors and camera added. I only had the thing working for two weeks before this happened. It may look bigger, but I assure you it's is about the same weight as a JD head.
I needed to use the micro servos because of space restraints so made sure of the weight as I knew that are not that powerful do using larger servos is not an option. These servos may be easily replaced, but I don't see why I should have to purchase another one when the one I have was used within its tolerance range and is faulty through no fault of my own. Besides, I'd have to pay extra due to overseas shipping on top of that.
hi steve G
are you using longer wires to get from the ezb4 to the head? are these wires all good.
@nomad.
Thanks for the reply. It does have one extention lead which I did check and replace (just in case) so I know that's not the issue.
@Doc and @oldrobotbuilder.
Thanks for the advice. I did what you both said but unfortunatly made no difference.
@DJ.
So could this be a manafacturing issue? Like I mentioned, I havn't used it that much, but the few times I did it, was working fine.
So after stripping the robot down to get to the servo and trying another to see if there were any issues, the test servo worked. I opened up the micro servo but couldn't see any visible burn marks on the PCB and all wires attached. I reassembled it to test it, but still dead.
