South Africa
Resolved Resolved by Steve G!
Where Does The Ultra Sonic Sensor Go?
I need help with this stuff, I'm not sure where to put the ultra sonic sensor in to on the EZ-B v4, which pins, what do I do on the ARC....Anything you know, please share... confused sickCan someone please take a pic of the ultra s on their board plugged in? I'm not a quick learner, and I learn better visually...... confused The videos for some reason are not helping me....
#17
The supplier is EZ-Robot. If they aren't currently in the store (they weren't last time I checked the store) then they will be added shortly.
As far as I know you get a regulator with the ping sensor in the store however check the details in the store to confirm that.
#18
I have the ping sensor from the V3 kit. I need to add a regulator to mine before connecting it to my V4, correct?
#19
Yes. The ping sensor will require a regulated 5v for use on the V4.
Do not connect the sensor directly to the EZ-B V4 VCC - This will damage the sensor
