What causes Dropping USB connection 0?
What Causes Dropping USB Connection 0?
What causes a USB connection on connection #0 to drop after 5-10 seconds?   I am connecting a Nano loaded with the UNO firmware. This is a new ARC project with no skills or scripts in it.  The board is plugged into the USB port on the PC and the Nano.  The device manager sees the port as COM3 baud rate is 57600 ARC is also set the same.
If I connect to 1,2,3,4,5   It stays connected with no issues at all
Can you.tell me how I can fix the issue with 0 connection note all connection setting are the same but only location #0 drops connection.
USB
Servos 12
ADC 6
Digital 14
EZB Connections by Synthiam
Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Com Port Manager by Synthiam
Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART.
Human-like audio via IBM Watson Text-to-Speech: multi-language, selectable voices for accessibility and automated interactions. IBM Cloud required.
DJ, your help is valued and much appreciated!   Yes you have helped me learn a lot about this hobby to the point it inspired me to make the XR-1.
