Azure Text To Speech icon Azure Text To Speech — Azure TTS for ARC robots: generate natural, customizable neural voices for companion, educational, assistive, and entertainment applications. Try it →
hi where does the sound comming from that dj uses from wally. blush
If you mean mechanically; the new V4 board will have the ability to attach a small speaker directly to the board it's self. Then you can store the sound files on your computer, use the computer's sound card to play the files and stream the file right to the EZB's speaker.
With the old V3 board we had to use a MP3 Trigger board or some other interface player where the files were stored on flash cards. ARC has a control that can play the sound files or use a script to trigger them. Another way would be to play the files stored on a computer and transfer them to the robot with a Bluetooth speaker receiver onboard.
If you mean the sound files; they are all over the internet. Simple searches will find many MP3 files.
hi is there a download somewhere for the wall e sounds.thanks
@dschulpius The V4 board has a built in speaker I believe...
that would be great
yes it has a sbuild in speaker
