All of the links to the kit from this post https://synthiam.com/Community/Questions/308
just go to the main store https://synthiam.com/Shop/
I don't know what kit I need to build him.
Set Digital
— Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only.
You need the developers kit...
hi where does the sound comming from that dj uses from wally. blush
If you mean mechanically; the new V4 board will have the ability to attach a small speaker directly to the board it's self. Then you can store the sound files on your computer, use the computer's sound card to play the files and stream the file right to the EZB's speaker.
With the old V3 board we had to use a MP3 Trigger board or some other interface player where the files were stored on flash cards. ARC has a control that can play the sound files or use a script to trigger them. Another way would be to play the files stored on a computer and transfer them to the robot with a Bluetooth speaker receiver onboard.
If you mean the sound files; they are all over the internet. Simple searches will find many MP3 files.
hi is there a download somewhere for the wall e sounds.thanks
I just did a simple Google search on Well-e sounds and came up with a ton of hits. Here's just one of them:
www.soundboard.com/sb/WALL_E_movie_sounds
@dschulpius The V4 board has a built in speaker I believe...
that would be great
yes it has a sbuild in speaker
