HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) — Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
@Bob... This is what I use for that... IR Detector
This will work too (depending on how low to the ground your bot is)... Basically an off/on analog switch... Short range IR sensor
These would use the analog ports and are easy to use... Roombas use this kind of sensor too to keep from falling down stairs...
Others have used a sharp IR sensor for this. I just mounted one to the front of my Roli, but I haven't written the script needed yet. The Sharp Distance Sensor ARC object stops the movement when you get too close to something rather than when you get too far from it, so unless DJ can add an object, we'll need a script to monitor the ADC port and over-ride the Movement Panel or movement script(s) when it senses a drop-off.
A ping sensor would probably work, but I think the IR sensors are more sensitive to close objects.
I use ir detectors for my wall-e pointing down.
The type of sensor only depends on the distance you need to measure. An IR sensor will measure short distances really well (a couple of inches) where a Ultrasonic sensor will measure a few feet. Also, the sensor you pickup for this could go further or shorter depending on the brand of the sensor. Ultrasonic isnt as good for really close up (a few inches) for the most part.
An OPB704 is an ideal sensor for that application but it does require a couple external resistors to be added in order to work well with the ez-b. There should be a few application circuits floating around the intertubes, but it's a common reflective sensor for robotics.
edit: It's best to hook up to an analog port just like the sharp sensors
Wow ! You guys are quick! An IR sensor it is then. Thanks
Since my Large Terminator will be as tall as me soon , I have ordered 1 more Ultrasonic sensor and the ARC sweeping mini servo along with a 150 cm maximum distance Sharp I.R. sensor to place up and down the front of the Terminator for a total of 3 and one at the back along with bump switches just in case. Will the Sharp sensor still need any added resistors as Jeremy mentioned back in 2015? Also Will ARC work with all versions of Sharp I.R.?
Hi @Robo Rad, the OPB704 is a different kind of reflective infrared sensor, so it needs some resistors to be added to make it function. If you are using Sharp infrared distance sensors no external circuitry is needed, as it's all built-in. The only thing you need to worry about with Sharp sensors is that they need to be powered by 5V for ideal operation. The output is from 0-2.5V I believe. It would work in ARC just fine. You just need to attach them to an Analog port on your ARC compatible controller.
Good to know Jer, I am just now pulling out the older EZB V3 as it makes a decent 5 volt regulator for all my sensors and it looks impressive with the blue heart beat L.E.D. and red bluetooth blinker going!
