Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Yes, it is possible. Ports 23 and 24 need to be forwarded. I haven't had a chance to do much with it yet to know how it works. Going off of a post DJ made about a month ago.
Ireland
Thanks @ d.cochran
Yes ports 23 & 24 open on router Have checked externally to verify both are open.
My query is on the remote pc on the web trying to connect ezb what is required .
I presume one enters your public ip address plus " :23 "in the EZB connection software
e.g 98.139.254.0:23
Here's a scenario which may be easier...
Computer A is your home PC running ARC, the EZ-B connects to the same WiFi network as this PC.
Computer B is your office PC, on a different network, in a different building or even in a different country.
Save the project from Computer A and save to the cloud or a portable device (USB stick, mobile phone, floppy disk if you still have some). Load up the project on Computer A's ARC Enable TCP/IP (connection tab) - default port is 6666 Port forward port 6666 on your home router to forward traffic on 6666 to Computer A Connect ARC to the EZ-B. Install ARC on Computer B. Load up the project on Computer B's ARC. Use Computer A's external IP address for the connection Connect You should now have both ARCs mirroring each other.
DJ did make a video of this a while back. I will see if I can find it. While his didn't show remote access over the internet there is no reason why a port forward wouldn't make this possible.
Edit: Here's the video
Ireland
Thanks Rich Explained and laid out very well
Basically one reqiures a local pc connected to EZB to login and control remotely from web.
one cannot log directly onto EZB using its unique ip address
As an alternative you can try Team Viewer..... Works pretty well...
I think you can log directly in to the EZ-B too, it should work (in theory). My concern would be the speed at which data is communicated from EZ-B to ARC over the internet though. By linking ARCs together you effectively eliminate this.
Ireland
Thanks Richard & Rich
I have a particular reason for connecting directly to EZB 4 from web if it were possible anyone already using this option please
Thank you Pat
Ireland
Eventually attempted to connect second pc to EZB on same wifi but get this error
Downloaded latest software on both pc's
win 8 connected to ezb ,win 7 second pc
