Hello there!
Can you tell me where i have to put the wires for the wireles camera and where to connect to the ezb-4.
Kind Regards Mvg, Jorrik
Cognitive Sentiment
— Detects positive sentiment percentage of input text using cognitive ML; returns $SentimentPercentage, shows face, graph, and status for analysis.
Hello there!
Hey Rich,
I like the wireless cam. eye for wall-e. The one in the developers kit is different.
it looks not as the same as on the picture you know!
But thanks for your help!
That's because it isn't the same. But it's better, much better! If you can fit it in I would highly recommend using the V4 camera over the wireless one from the V3 developers kits.
You probably thought it was 5v because it has a USB charger, so if you power through the USB port there is either a regulator or the battery acts as one. Before trading it to another member, I powered mine with 5v from the EZ-B v3 with the battery removed and it worked fine.
Okey Rich.
Than i will try both, so i can see whats better !
Can i also use the mini usb input of the wireless cam to power it from the ezb -4?
Re: mini USB. Yes, but again, you will need a voltage regulator to bring the power down to 5v.
Okay Alan,
Thanks a lott for helping me!
To all of you, thanks a lott that you helped me with this project!
Mvg, Jorrik
