Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
Wireless cam? Are you not using the camera which comes in the V4 developers kit then?
If not, what camera is it? If it's wireless what wires are you trying to run?
There is a cable supplied with the EZB-Camera that is used to connect into the EZB(4) controller.
I suspect you have a V4 Developers Kit? Or just the v4 on it's own? If so, there are tutorials which explain the ports and connections. Here are some direct links to help you along.
*Note: The LEARN section can be accessed by pressing the LEARN button on the top menu of this website...
Developers Kit Lessons: https://synthiam.com/Tutorials/Course/4
v4 overview: https://synthiam.com/Tutorials/Lesson/12?courseId=4
And here is an image of the v4 from the Overview page...
If it's the camera that came with the dev kit, it should have came with a white ribbon cable already attached to the camera like in the picture below. It only connects one way around but be careful when you plug it in as it can easily be forced.
Once your camera and cable are connected, plug in the white ribbon cable in to the camera port on the EZ-B pictured below.
Now your connected here's how to get it working.
  1. Load up the most latest version of ARC.
  2. Click on the"Project" tab of the ARC top menu.
  3. Click on "Add Control" on the menu ribbon.
  4. Click on The "Camera" tab.
  5. Then click on the "Camera Device" icon to add the camera.
  6. Finally connect your EZ-B to ARC and the camera stream should be displayed in the camera control.
If the camera in the first photo is different to what you have, maybe you could post a picture of it.
EDIT:
I see DJ posted while I was writing. The links he has supplied will be a great help to you as well if your unsure of anything.:)
Netherlands
Hello There,
Thanks to all your kindness for helping me with my project.
Your duplicate thread has been deleted. Please this post, which is your original thread - post in this thread for questions regarding the same topic. Thanks!
If this is your camera, you need the USB dongle for your computer... The camera is wireless (Bluetooth)...
Netherlands
Yes i have this one! I want to connect the cabeles for the power of my camera from the ezb-4. or extern battery. where to put the wires? confused
How to power the Camera from the ezb-4 and where on the board of the Wireless cam?
