Serial Terminal— PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hexTry it →
@nomad.. Ha, Ha for you, that's 3 Euros dude...:P To be honest, I would be happy if when you ask for help you really try and listen so it doesn't take 20 plus posts to get to a solution for you...
found another way to get better sound and louder too.
i use swifttalker set volume high.then i make it higher with,
the mp3 volumer.also there is room for a speaker in jd head.backside.
i connect that straigh in the ezb.do this only when you are a good ,
at soldering.i found this robot but its a litlle empty,no cam or rgb.
you can ad.but it would fit an ezb.so here a little video with,
sound not at highest level.
@Rich... sweet! only 224 to catch up to you... and that's assuming you quit solving questions....
@Doc... actually, nice find!
thank you all guys.
rr
i get you 3 bucks.
robot doc it works.
rr do you know i read avery post 3 to 4 times,and still not be able, to understand.i just dont have it,but i try.
found another way to get better sound and louder too. i use swifttalker set volume high.then i make it higher with, the mp3 volumer.also there is room for a speaker in jd head.backside. i connect that straigh in the ezb.do this only when you are a good , at soldering.i found this robot but its a litlle empty,no cam or rgb. you can ad.but it would fit an ezb.so here a little video with, sound not at highest level.
Nomad,
What robot is it? It looks very good.
Where did you get the neat 'armor' or uniform for it?
Keep up the great work and thanks for sharing.
oldrobotbuilder
its an alpha 1 S from ubtech.sold at banggood.com 460 euro+54 chipping, belgium.i june alpha 2 comes out. 1200 euro.
it has a full alu frame.you can charge batt while programming the robot.
there is allreddy an app for adroid or ios.
thanks
@Nomad,
Can you create a video of the robot walking forward, back, rotating left & right.
I would love to get ideas to improve the JD.
