Screen Recorder icon Screen Recorder — Record your screen to WMV1/WMV2/H263P files with selectable bitrate, save-folder and start/stop controls, creating tutorial or demo video snippets. Try it →
Voice Activated Door Lock
Today I discovered the obvious. You can not only control robots with the EZ-B but you can control any peripherals compatable with it. There a so many different possibilities, varying from simple to complex. So I have set out to create a simple voice activated door lock. I am still in the planning stages and I hope I will be successful. Here is the link. The key will first rotate to lock or unlock the door. The pinion will then rotate moving the servo back. This whole mechanism is contained within a metal box which can be slid across to reveal the door knob.
Thanks for that. That will definitely work. Scripts are perhaps my favourite part of ARC. They are brilliant!
#26
I'm going to think of a way to make the scripts all fall into one control. Someday... because there are LOTS of controls which takes up screen realestate:(
and PS, your nickname is very accurate... you're super creative! it's impressive
Thanks. But I wouldn't be able to do any of this if you hadn't had the idea and if you didn't feel passionate about robotics.
