Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Using Touch Pad On Mobile Interface
OK, I'm just not getting it. But looking over the controls in Mobile builder I do not see a control for touch pad even though it says its supported. Could someone tell me how the heck I set it up and what controls to use?
Thanks in advance.
I was creating a blank test project. Once I added servo pad I saw it listed in cheat sheet. I added it to my button via instructions from Steve, then saved the window and the project to the cloud. I downloaded it to my Iphone 5S and got the above error. I am using the latest of both ARC, windows and mobile ios.
One last question, why does the interface come in all squashed to the left side? I also opened the desktop on the iphone and it was also squashed to the left, like prettty much just half the iphone when in horizontal position.
Thanks in advance.
  1. A blank project will not have any references in the Cheat Sheet to the Touch servo Pad. You will have to add the touch pad manually with the instructions from this page: https://synthiam.com/Tutorials/Help.aspx?id=150
  2. Apple has a reported bug with some apps doing that - it's because you haven't updated to the latest iOS, which I believe is 8.3? On your iOS device, go to Settings -> General -> Software Update
  3. When you press ABOUT on the ARC Mobile, what version does it say?
  1. I understand that
  2. nope still on iOS 7.1.1
3)v2015.03.19
@fxrtst.
When I tested it out I was using iOS version 8.2 on an iPhone 6 plus. iOS 8.3 is the latest release as DJ stated, so maybe that could be an issue.
Ok might have to update my iPad and iPhone, I've held off as long as I could:)
lol, updating is a good thing!
Your ARC Mobile is very out dated. Update to the latest iOS, and update ARC Mobile.
#15
Ok broke down, updated ios to current on one of my devices and downloaded the newest version of the mobile app. All working now. Thanks for the help.
Is there any chance that the UI for finger pad will be an added control from the left hand pane in the settings tab in the near future?
Also any chance the Blink M controls will be ported to the mobile?
