Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
Trouble With Sound Servo
Hello,
Back after some absence. I'm having trouble with my EZBv4 and getting sound servo to work with the latest version on EZB Builder. Sound servo (PC) crashes the EZB software. with an exception error. I tried on two different laptops and got same error message and crash. If I choose the sound servo (EZB) I get an error message at the bottom of the screen that says sound object is being used elsewhere.I've rebooted the machine thinking that something else was using it. Same thing.
I'm trying to talk live into the microphone and have a servo controlled by my voice. At this point Id be happy to get an mp3 or wav to work with sound servo. Any suggestions?
Sorry, I actually have never used this control. Someone else is going to have to chime in on it. I am interested in this but have no experience at it.
I get the same error now with version 9.16.14. Never did before. Infact my Bender robot project won't load now. This is for the Sound servo PC:
Errors are gone with the newests new version of 9.19.14. DJ's the man! I'd download that version and give it a test again. Did Sound servo (pc) work for you prior to the Sept. updates?
This is how I setup my and it works well a pc MIC. You should see the level change as you speak as well as see the servo move. Keep in mind, you can also select n/a for the port if you want to test to make sure your mic is working. It will still change the volume level as well as the variable value.
Also my update speed is set to 500, I wanted mine slower. For a mouth you may want the fastest setting at 100.
I read somewhere that the commands or not the same for the PC and the EZB. Maybe the script doc will tell. There is a command to place the sound out of the PC and another to place the sound out of the EZB. They are not the same commands.
Thanks All got it working with the update from DJ
Is there a trick to getting speech synth to work with sound servo. Seems to want to only listen to my mic on my computer.
#15
Sound servo PC will only work with your PC mic. If you don't want to use your mic and you have an EZbv4 you can use Sound servo (ezb) and it won't use the mic output it will use the sound output.
One works only with the mic. The other works only with v4 and uses the sound output (not the mic).
#16
Thanks Justin!
