Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
Speech Synthesis Markkup Language
I was wondering whether it is possible to use elements from the Speech Synthesis Markup Language to modify the speech output using EZ-script? Or if there are other markup options other than the ones already given in the Speech Settings Control?
no markup. You can create a plugin to do it
Right, that's what I thought. Thanks for the speedy reply!
Also... You can add the speech synthesis settings control (https://synthiam.com/Tutorials/Help.aspx?id=156) and write your script like..
sayezbwait("Hello")
ControlCommand("Speech Settings", SetVoiceEmphasis, "Strong")
sayezbwait("I am speaking strong")
ControlCommand("Speech Settings", SetVoiceRate, "ExtraFast")
sayezbwait("Now i am speaking extra fast")
ControlCommand("Speech Settings", SetVoiceRate, "Slow")
sayezbwait("Now i am speaking super slow")
Yes I realize that. I was looking for a more fine-grained way with which to control the prosodic contours, and the breaks between strings. The method above is a bit too coarse for that. The SSML is a step in the right direction, so I was just wondering whether this is something that could be used in EZ-script.
However, using the SDK is perfectly fine, but thanks for the followup.
Great! Let me know if you have any questions about creating a plugin for this.
Based on my findings you can indeed use at least some SSML elements in ARC, it's been extremely useful when developing Dorian's voice!
@DJ Shame on you for not having more faith in your own amazing software!;)
This works just fine if you're using either a Cepstral or CereProc voice:
#The </prosody> tag is only needed if you're going to make other changes mid-sentence, otherwise you can just use the first tag and don't need the second one after the string.
$VoiceStart = "<prosody pitch='-50%'><prosody rate='.40'>"
$VoiceEnd = "</prosody>"
SayWait($VoiceStart + "When I'm tired my voice gets very deep and I speak slowly" + $VoiceEnd)
Here's a video I made for those who prefer video format when learning:
Thanks for the tutorial @Sebediah!
I was thinking about purchasing a Cepstral voice just recently, this knowledge would definitely be handy when wanting to modify a voice with EZ-Script.
Sebediah, Thank you for your interesting tutorial. My robot Artamus uses a Cepstral voice, and I was able to alter his voice using your examples. Alexa has a hard time understanding him, maybe this will help. Either way this allows me to customize his voice. Steve S
