Hi,
Could someone please tell me what the size of the camera is after it has been taken out of its case including removal of the front lens surround?
Thanks heaps.
Rich & Phoebe P.S. Sorry for this duplicate post.(in hardware section)
Roomba Tones
— Deprecated Roomba control; replaced by the iRobot Roomba Movement Panel for updated movement control.
Hi,
Thanks heaps.
Richies rc , based on.the size of your bot I don't see any reasons why dj cam won't fit inside once the case and outside lenses cover is removed. I gave measurments of outside of the cam on accident , the insides significantly smaller especially if you remove battery and power directly from your robot.
@kkeasthe
Thanks Kevin,
There are many differant types of these systems but from the outside they all look very much the same. I learned about them with my radio control hobby/business and are used mainly for FPV(First Person View) this is where the unit is mounted in your model(mostly RC planes and Helicopters) and instead of flying using your own eyes(looking at your model from the ground) you fly using either a video screen or special goggles. These camera units are also available in 900mhz so they can be used with 2.4ghz radios without any interference. The range on many of the new 900mhz units is well over one km so you would not be able to see your bird, only from your monitor or goggles(just like being in the cockpit).
Anyway I will give it a try once the EZ-B controller arrives seeing I have it just lining around.
Phoebe and I will take some photos later today of Wall-e's progress. His body is totally finished and are in the middle of drawing up his arms and head/neck.
Rich & Phoebe
@jstarne1
G'Day,
If possible would you be able to give me those sizes?
Thanks Rich & Phoebe
