Omron HVC-P icon Omron HVC-P — Omron HVC-P ARC plugin: real-time body, hand, face, gaze, gender, age, expression and eye estimation; facial recognition via Omron software Try it →
I'll measure precisely tonight, but it is around 1" wide znd less tvan 2" long.
A little bigger 1.5 wide 1 in tall without stand 2.5 long. Still small though.
Germany
Would 2 of them fit into the U-Command Wall-E Head?
G'day Alan and jstarne1,
Thanks but don't think it's going to be small enough, as it is going to be mounted next to Wall-e's eye socket and not in his eye. I have had this micro camera for ages and will give it a try (works fine in the ARC Control Software. and has a 400 feet range.
Specs are: Specification: Camera Dimension : 25.75 X 22.03 X 22.25mm Camera Weight : 20g Image Pickup : 1/3 Format : NTSC or PAL Scan Frequency : NTSC: 60Hz, PAL: 50Hz Min. illumination : 2 Lux Resolution : 380TV lines Output Type : Color TV output Output Power : 50 mW Output Frequency : 2400 mHz (2.4 GHz)
Came with: SpyCam miniature camera @ 2.4 Ghz Receiver Video Cable to Connect TV/VCR/Camcorder 9 Volt Battery Adapter + FREE 9V Battery Power DC Adapters for both the Camera + Receiver
Needed to get one of these, Easycap USB 2.0 audio video capture device.
Rich P.S. keep an eye out for a the weekend
Germany
Such a micro camera sends its signal over wifi, if Im not wrong. Is it possibe to receive the video of the camera directly on the laptop? Or is it maybe even possible to let the micro camera connect over wifi to your router and upload the video, so if a burglar breaks into your house and even destroyes your router etc. you still will have the videos until that moment saved online?
@RichiesRC,
The only thing you need to know for sure is if the capture device above will be seen by windows as a webcam device. I have a Diamond One-Touch Video Capture VC500 device simular to the one above. It did not work with ARC. I think it has to do with the drivers and how the device is seen by the operating system. I have to use the Diamond proprietary software to make it work for video capture. Unless someone has tested this, i would say it is not a guarantee that it will work. I have the camera DJ advertises and it works very well.
v/r
Kevin
@kkeast
Hi Kevin,
Well I will try it first as the size of the EZ-B Camera is just to large and won't fit as I have already stated and also the video is clear as day with my mini 2.4 ghz camera in the EZ-B software, this camera can also be used as a web cam so it should work. It has nothining to do with not wanting to purchase DJ's camera. This is for a scale model of Wall-e with over 20 servos not a plastic toy converted.
Rich
@RichiesRC, Glad your capture device is working for EZ-B. I may get some of the ones you show above if they work with ARC as I have two of the cameras you show above. My problem with those little cameras is not the range but the interference from other RF and when I don't have good line of sight between the receiver and transmitter.
Depending on how you enclose it you may want to do some testing as that antenna is tiny. I would be interested to see how it works out for you. They are really small cameras and the video is not too bad. We use the cameras for our Cub Scout Pinewood Derby, which is where we run little wooden cars down a track and found for best results you need to keep the line of sight.
Understand your size limitation for the camera...those things are very small. For others, I will say that the camera DJ found does have great range even through walls and stuff.
Best of Luck! Can't wait to see more of you and your daughters project! Its looking great!
v/r
Kevin
