Bing Speech Recognition icon Bing Speech Recognition — Accurate Bing cloud speech-to-text for ARC: wake-word, programmable control, $BingSpeech output, Windows language support, headset compatible Try it →
Servo Shutting Off Ez-B
Hello,
I have just bought some metal gear servos for the robot I am working on. When I go to plug in the servo into the EZ-B it just causes the board to keep shutting down. Is it drawing too much voltage or current?
It is these two Kookye Servos:
www.amazon.com/gp/product/B01I6AWBJI/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
What is the power source you are using to power the EZ-B and servos? Initially I would say It does sound like the power source you are using is not providing enough current for the servos causing the EZ-B to shut down. Also, there’s no mention that I could see using the link, of what the operating voltage is for these servos. Did you receive any documentation stating the servo voltage with these servos?
Have a look at the following tutorial, specifically steps 4 and 5 about different power supply’s...
https://synthiam.com/Community/Tutorials/163/4
Those servos will draw A LOT of current. About 3-5 times more than ezrobot HDD servos. Their efficiency rating is super low. That means they’re drawing more than your power supply can provide.
I see this often on the forum for people who purchase cheap servos to save a buck. But it ends up costing more in the long run because you’ll find power sources drain quickly, they’ll vibrate and be noisy, generate a TON of heat and overall discourage the build.
You won’t find servos as efficient and reliable as the ezrobot HDD’s
It's best to use the EZ-B for your logic control, and use a separate power bus to feed any current drawing devices that are a part of your project. It is important that the two SHARE a common ground so your logic outputs have a closed pathway.
Yeah it ended up being the cheap servos just being rainbows and buttercups. I took them to an RC hobby store where I live and as soon as the guy plugged them in to test them they both sent out smoke. I walked out with a good servo that works perfectly plugged into the EZ-B.
Glad you got to the bottom of the servo issue. I've used el'cheapo servos a long time ago with mixed results. Defiantly worth paying the little extra for quality servos. I have to say that the EZ-Robot HDD servos are great. Silent and strong and reasonably priced.
@cubco
That really sucks when you buy something (no matter the cost) and it turns out to be junk. The heavy duty digital servos offered by EZ-Robot are the best for the money. Can't beat them. They also have an incredible lift of 19 kg/cm. Need to check out the video on this site.
Why did my message change to saying "Rainbows and Buttercups"? LOL. I have never said that in my life. Did I curse and it changed it to something else?
Anyways I was just supporting our local hobby store. From a small town and would like to keep them in business. I am sure the servos from ezrobot are awesome. Seems like they only put out good stuff.
Now I can only think of rainbows and buttercups... and I'm not sure what buttercups they are talking about but I am thinking of the ones with peanut butter.
Lol, The rainbows and buttercups are part of the forums bad language filter that replaces not so nice words with something a little more friendlier so as to keep it family friendly.:)
