SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
It's possible but you will need extra hardware and a custom plugin. I did that to avoid wifi connection. I can post a video if anyone is interested.
@ptp, I would like to see your video. I'm not a programmer so I wouldn't know were to start for a plugin. Do you have a link for the hardware to connect the ezb camera?
Thanks, merne
Merne,
Quote:
I'm not a programmer...
No problem, I'll explain how it works.
The EZB Camera uses serial communication, the baud rate is fixed and high, common USB/Serial/TTL adapters can't handle the high baud rate.
I have tested a few different chips and no success, i have one more high end but I'm using in another project (I'll test later).
I don't know if EZR can recommend one.
Quote:
those without a dog hunt like a cat
I used an Arm Cortex M4 to interface with the ezb camera.
The code logic is: read from the camera write to the USB, read from the USB write to the camera.
the first part of the problem is solved.
ARC connects to the EZB camera via IP + Port.
I built a custom program to bridge a TCP Server listening on a specific port and the camera USB port.
The code logic is: read from the TCP socket (remote client=EZBuilder) write to the serial port, read from the serial port write to TCP socket.
I'll post a video.
If you are interested drop me an email, i can detail the costs, i can buy the micro-controller, flash the code, and send it to you.
The custom program can be converted to an ARC skill plugin to keep the solution centralized.
@ptp, I just sent you an email.
Thanks
@merne,
Sorry for the delay, busy and a few personal projects, the usual.
The plugin is out: https://synthiam.com/redirect/legacy?table=plugin&id=186
The controller on the picture will be in the mail tomorrow.
You will be the Plugin's user #1 (excluding me)
There are more ideas ... to use the extra micro-controller with EZ-B.
Maybe (maybe) in the future i can release a firmware tool (similar to the EZ-Robot) to program the micro-controller without extra tools.
The problem is always the time.
If anyone have the same request, i can help replicate the setup.
@ptp, this looks great. I briefly took a look at your plug-in I will look at it more this weekend work is been very busy .
I look forward to receiving the controller and thanks very much for your time.
Thanks merne
#15
Would using a raspberry pi with the EZB4 be a better solution?
Once the script is loaded onto the hard drive, once you unplug the usb the robot would perform the script? Would be more reliable than a wi-fi connection i think?
The Pi can act as a USB slave, or act as a virtual webcam, etc.
@NewAgeTomy
I can't follow you.
When you connect an ezb v4 or iotiny to your desktop you lose the camera port.
using a plugin and extra hardware you can connect your ez camera to your pc.
Both the controller and the camera are wired.
Raspberry pi does not have a serial port so how can raspberry pi be a better fit between an ez-robot camera and a desktop usb port ?
