Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Hey @Wolfie don't give up! Scraps is a cool looking bot. I'm sure that you could pick up some higher torque gear motors and get em' up and running right!
Lots of members here could probably suggest some good DC gearmotors (and motor driver) to use. FingerTech (from Saskatchewan) has a large variety of DC gearmotors in various ratios that they usually sell to battlebot enthusiasts.
I usually get my DC gearmotors from Princess Auto or Electronic Goldmine because of the surplus prices.
Im not giving up Yes I can get new motors but it would be a mager job finding ones that would fit in the little space I have for them Im best to get a completely new drive base to work with It will safe time and ALOT of stress lol
Plus the plastic gears suck big time Time to change over to metal
mmmm more power lol
wolfie
i saw your video off scraps,he's way much better then mine. maybe you can double the dc motors.
I have no room in the motor box that is about the size of 1 servo cut in half and the 2 parts put together end to end lol
By weak do you mean slow or do you mean lack torque?
You can get a whole variety of motors of the same size which have different speeds, torques and voltages, you may be able to find something which better suits your requirements.
It was mentioned a while back that the RAD robot gives much more torque when over volted but run with PWM to simulate lower voltage. So in effect a 6V motor running on 12v with PWM at "half speed" gave it more torque without damaging the motor. I can't guarantee that wouldn't break the motor but if replacing them anyway it may be worth a shot?
I think I would be best to get a different drive base one that is bigger and stronger The motors in this one are way to slow and week plus the plastic that the base is made from is thin week and flimsy It was ok to play with and learn on but now its time for better There is many things I want to change on it so it would be less work to get/make a new bigger stronger drive base with bigger stronger new motors But I love the tracks so I have to keep them lol
I agree. Sometimes it's time to put away the toys and start running with the big dogs! cool
I'm the king of dogs lol Dogs love me Cop dogs are pups when I'm around lol
