Kinect Xbox 360 Depth Mapping icon Kinect Xbox 360 Depth Mapping — Converts Xbox 360 Kinect depth frames into NMS obstacle scans for ARC path planning, SLAM, and obstacle avoidance. Try it →
Not sure what you're asking. I think you're asking is the 360degrees Continuous rotation 360degrees HDD?
If this what you're asking then no. At least that's what the product description says.
However, someone more familiar with the product should know for sure.
The HDD servo like the one you show has the EZ Bit on the servo and the square bit for a servo horn. That way you can use the servo with your EZ Bits.
The new HDD servos can use the same servo horns as the old HD servos from EZ Robot.
