Websocket Client icon Websocket Client — WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status. Try it →
Robot Does Not Work
Something is wrong. when i connect ez-b to computer it gives me two ports COM3 and COM4. But on tutorial video shown COM3 and COM7. I connect to COM3 as it is shown in video. When i try to open examples botton it does not give same window as shown in video. (picture attached) In this window i cannot open calibration example project. It just not there. If i just go to Add-servo-modified servo Movement Panel and start to modify servos it works (sometimes) or led on ez-b and bluetooth turns of and servos start shaking. sometimes one arm goes up in the air,sometimes head while leds are off. and it goes up or down not smooth, it shaking, like moving mm by mm and i have to disconnect all servo leads from ez-b to stop them shaking. if i just reconect power it keeps shaking. what is going on?!
I have everything working first. But at some point lights go off. Ok. I will try batteries and i will post another video. Thank you!
Post a pic of the voltage and amperage of the power adapter you are using please:)
I am using batteries now. So far everything is ok. But how do i configure his left and right arms? When i go to add-servo i have auto release, auto position,auto position movement panel,horizontal servo,modified servo,modified servo movement panel,relative servos,servo speed,sound servo,vertical servo,servo summary. I used horizontal and vertical for his head movements and modified servo Movement Panel for his wheels. And i dont see here anything that can be configured for arms. Please someone. I am brand new in robotics. I need help. Thank you!
Dj Sures! I got MP3 trigger and i found some Wall-e sounds online> but i still did not find that sound when he gets upset when ball is taken away. Could you please email me that sound. It is small so it will be easy to email it. Please!
#15
@alexbjj I'm glad the batteries are working. I'm pretty sure you just need a different power supply. I use vertical servo controls for my arms. gotta run.
