Single Camera Servo Server icon Single Camera Servo Server — TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control Try it →
Revolution Roli Rover Robot
Hi, I,am a total novice and I have just purchased the Roli Rover Robot .I have followed all of the tutorials but have the following issues: (1) I can get all functions to operate except for the tracks and camera picture. I have checked the wiring instructions as in the tutorial which seem ok but the tracks do not move. (2) One of the three servos moved smoothly for about two minutes but then became juddery when moving and the actual servo was warm (3) The contents in the box was correct except for two addition wired cables with black end plugs they are about 12" long , the cable colours are white-red-black, they are not mentioned in the box contents tutorials or in any assembly instructions
Can anybody help, I,am located in the U.K. Regards, Paul Nicholson
Hi Ed, thankyou for the information, it is hard to tell if there is a protective film on the lens but I will take into my works and look under microscope to see, again thankyou. With regards to the tutorial I have gone though all of the proceedures but it is hard to tell if the camera is vari focal or foxed focal and it seems the method of adjustment seems a bit risky to me if you slip with the pliers and damage the lens. EZ should mark the cameras if they are fixed or vari focal.
Thanks Again,
Best Regards,
Ian Paul Nicholson.
Hi Ed, I have solved the problem with the camera, after inspection through a microscope at work there is "no actual lens fitted" what I thought was the lens was the actual microchip. I,am trying to get a warranty replacement from EZ.
Regards,
Ian.
