Soundboard (EZB) icon Soundboard (EZB) — Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators. Try it →
Revolution Roli Rover Robot
Hi, I,am a total novice and I have just purchased the Roli Rover Robot .I have followed all of the tutorials but have the following issues: (1) I can get all functions to operate except for the tracks and camera picture. I have checked the wiring instructions as in the tutorial which seem ok but the tracks do not move. (2) One of the three servos moved smoothly for about two minutes but then became juddery when moving and the actual servo was warm (3) The contents in the box was correct except for two addition wired cables with black end plugs they are about 12" long , the cable colours are white-red-black, they are not mentioned in the box contents tutorials or in any assembly instructions
Can anybody help, I,am located in the U.K. Regards, Paul Nicholson
Hey Paul, The long cables would be used to extend the servo wires at the end of the arms. This will prevent binding.
On the camera, do you get a blue light out of the front of the camera when the robot is on and the camera control is started?
On the servo for the arm, was there any binding that was caused by the wire being tight? Are all of the other servos moving without any jitter?
On the tracks, please look at this page to make sure that all of your wires are attached correctly.
I believe David was planning on adding a link to this page: https://synthiam.com/Tutorials/Lesson/69?courseId=3
Note: the page says that the button should be down, but if all the wiring is correct, and it still doesn't work, try with the button up. A few H-Bridges seem to have it backwards.
My bad... Thanks Alan. My son was here and I had to help him move some things. My brain got distracted... DOH!
Hi, your help is greatly appreciated, I have checked all of the wiring and it seems ok, the rest of the servos are fine I swapped the suspect servo with the other arm and the fault is defineately with the one servo the rest are fine (the servo did run smoothly for the first few operations then started to judder). With regards to the tracks not moving, if the fuse has blown would this cause the servos not to function as well, or is the fuse just for the tracks. I removed all of the moving servos on the arms and camera and just left the tracks wired and tried again, still the tracks did not work. I have not configured any of the servos could this be the problem with the faulty servo.
Again your help is appreciated,
Regards,
Ian Paul
@Iannicholson1950 Are you talking about the 20amp (yellow) main fuse in Roli's body? If that blew then your ezb would be completely dead so nothing would work period, including any of the servos. I don't have a Roli so I don't know if there is any other fuse.... Anyway if that fuse blew I would go back and again check all the wiring carefully to make sure they are plugged in correctly to the H-bridge. Then I would go back over the Roli learn section step by step again... Pay attention also to that little button on the H-bridge.... sometimes for what ever reason it needs to be down while other people report it needed to be up in order to get Roli's treads to drive...
Please check the position of the button on the h-bridge(motor controller) in Rollie. Try changing the position of that and see if it works. I do not think that there is a fuse for the tracks.
Hi I have moved the button to the up position and the tracks now move, with regards to the camera a green light is visible when the camera is switched on. You can see a very blared image on the screen so I thing it will need the camera focusing I will look on the tutorials for help with the camera. At least the tracks are now operating, again thank you for all your help it is really appreciated, Best Regards Ian Paul Nicholson
Hi sorry to bother you again with regards to the camera it looks like it is not a vari focal lens when the camera is switched on you can only see faint shapes, but if I put a cotton bud touching the lens you can actually see the strands of cotton on the picture have you any idea what the problem might be? Regards Ian Paul Nicholson.
