Hi everyone, is it ok to share my project here?
I wrote an intro post and when i went to send the whole page disappeared and i lost all the text.
It's around 80% completed.
Azure Text To Speech
— Azure TTS for ARC robots: generate natural, customizable neural voices for companion, educational, assistive, and entertainment applications.
Do the photos have to be a certain size for my project thread?
I included the youtube video, added pictures with descriptions and it simply wont work.
I've changed to a different browser but i can't start the thread, would my photos be too large?
Can anyone help me please?
I inserted this Youtube video of yours by coping your Youtube link you posted above. I then clinked on the button that looks like a little black box with the white arrow in it. You will find that button on top of the comment window. Once I clicked on that button I got another window that opens where I will inserted the youtube link. Then I clicked insert. When you do this make sure your curser is in the place you want the link inherited.
When you want to insert a picture make sure you chose "Upload Image" from the insert image button and follow it's instructions.
Hi Dave the video works but in the actual robot project thread I'm trying to create...nothing works.
I haven't seen any documentation regarding a certain photo format or photo size.
I resized all the images and it still wouldn't work...:(
The link always appears in the thread as do the photos, but every time i go to publish it fails....many many times I've lost count.
Yep i followed all instructions and have been on many other forums in the past, I've never had so much trouble trying to create a thread.
Can you try to post the video here and see if it works? If so it's a problem with the site.
I've never had a problem with file size. If linking to a working vid on Youtube using the proper button there should not be any issues like that anyway.
https://youtu.be/hGY9Y6ogymg
Only shows the link doesn't embed.
It works on the build thread, but for some reason it resets the default cover image every single time...
I will try on one more browser, if it doesn't work then I'm afraid I won't be able to show irt.
Can i ask for help somewhere else?
I'm really needing help assigning the servo profiles.
Looks like your not using the proper Youtube button located at the top of the conversation window. Are you just posting the link?
For help you probably only need to start a new topic. Select the question option when starting it. CS usually answers within a day. DJ is usually keeping track also.
Sorry, I've never had to use servo profiles.
