Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Is it the whole left side, or just an arm or a leg or one joint?
You say the whole of the left side (except the claw)? Ok, here's a few thing to look at first. How are you controlling JD? Are you using the JD project within ARC, or have you set up your own ARC project?
You might want to double check that the ports that the servos are connected to are configured correctly within your servo control in ARC.
Are the servo cables connected to the EZ-B correctly (the right way around)?
What are you using to power JD? If it is a battery, is it fully charged?
I know you mentioned checking the instructions, but have you had a look at the Learn section for JD to make sure you have done everything correctly?
Singapore
Thanks. It was the way the wires were plugged in. Not obvious in the instructions but the black side of the wires was on the wrong side. All servos are now connected but JD does sit ups and head stand like he has been up all night drinking. I am using the downloaded profile that DJ built. Seems off balance and some of the actions are happening in reverse or something.
If actions are not performing as programmed then you need to check the orientation of servos and calibration. Pay attention to the instructions, they show the correct orientation for the servos.
If it seems off balance you need to check and recalibrate and then possibly fine tune the servo profile.
Follow all lessons for JD in the Learn section, this will tell you the correct polarity for the servo wires, how to calibrate and how to enjoy your robot.
Also, all digital ports on the EZ-B are colour coded for ease of use. The black wire from any accessory needs to connect to the black pin on the EZ-B. This is also covered on many tutorial videos and lessons.
I'm glad you got the servos working now. As you're using the JD project and a servo turns in the opposite direction, it could be how the servo is fixed to another servo or EZ Bit. Simply unclip the servo that's causing the problem, turn it 180 degrees and re-clip it back in to place.
If things seem a little of balance, then like Rich mentioned you will need to fine tune the servos by calibrating them. The calibration links for JD are in the learn section but I have linked them for you below. Hopefully this will help sober JD up a bit.:P
Lever servo
Shoulder
Head
Feet
Hand/gripper
Singapore
Thanks for the feed back. All of the servos were fine except for one foot. Turns out you can only calibrate the plate on the servo not the servo in the foot. I attached an image. Also I tried to re-built bur the instructions in the ARC software don't let me restart the instructions, When I try to go back I get an error message as in pic attached. I can't get back to see what port each wire gets connected to.
Singapore
How can one delete a post?
You can't, only ez robot can... However, you can edit your post...
