What is the trick to putting the case of the body back together for JD? I took it apart to lengthen the charging wires to the battery and it won't fit back together. The shoulder servers are in place, I know the battery goes in the bottom, but the battery cable where does it lay inside the case?
— Edited
@SteveG, this also make the second thread of mine where you have thanked yourself when I did not thank you nor did I intent to.
I do appreciate you "attemping" to help me, but frankly your comments were not helpful to me. And thanking yourself is not cool. I've seen you do it in a few other threads to.
Just like I appreciate Nomad who really tried hard to show me what I needed to see, but it was only Jeremie who's response showed me what I needed to see and made sense.
I have been there with you in few threads where I felt like I may have answered a question and didn't get picked as the solution finder but I've never said anything because I assume the information I presented may have not been what the person found helpful in way that made sense to them. It just makes me want to try harder next time to understand what information people might need.
Even though it was the same answer Jerime gave you which he apologised for? I didn't think here was anything "confusing" about "Slide it inbetween the ends of the servos and battery". If you wanted me to explain what I meant further you should have asked. And as for thanking myself, this is something I DO NOT do. I give a "Your welcome" comment as a nudge to the person I tried to help where no thanks is given or the information offered is completely egnored, which frankly, is rude. I'm never looking for thanks as I'm always happy to help where I can, it's just common curtesy for someone to give thanks when someone takes the time and effort to help, and perhaps more people should try it. It would make the world a better place. But I digress, it's not about the credit or anything, I just wanted to help you with my solution, and like I said, I'm glad you got it sorted.
