Resolved Resolved by Jeremie!
Putting Jd Case Backtogether
What is the trick to putting the case of the body back together for JD? I took it apart to lengthen the charging wires to the battery and it won't fit back together. The shoulder servers are in place, I know the battery goes in the bottom, but the battery cable where does it lay inside the case?
It won't fit laying like the picture show SteveG.
Okay then. Maybe post a photo or two to see what's going on if you can. Are you talking about the red connector that connects the battery to the power switch seen in the first photo and below? The only good place I can suggest is slide it inbetween the ends of the servos and battery if there is room.
To help Justin out, I can recommend taking the two deans plugs together, locate the thinner side of the plugs and tuck them inbetween the battery and the servos. Then make sure that it is positioned more toward the right side so it doesn't run into the micro deans board that fits very closely beside it when the two plastic enclosures go together.
Yup, that's exactly where I meant. It will be a snug fit but should fit nicely as seen I the photo above.
lol my apologies Steve I should have "read" your post instead of just looking at the picture.
Thank you, thank you Jeremie! That is what I needed to see! Now JD's body fits back together. :)
But one of the corner posts broke (on the back cover) when the screw head when through the thin plastic at the bottom of the post. Have you ever had that happen before? Any easy fix? I was thinking of maybe getting a tiny washer. Or should I print a new back cover?
#15
@Justin.
I'm glad my suggestion I mentioned on post #11 worked for you. It's a snug fit but it stops the battery moving about too. Not sure why Jeremie got the "thanks" or the credit though, but I'm glad I could help and pleased you got it sorted.;)
#16
Jeremie showed me the picture I needed to see and answered my question in a concise non-confusing way. I picked his over your answer for that reason.
I did not find your comments helpful to my question and your comments did not help me find the solution I was seeking.
