Feetech Serial Bus Servo icon Feetech Serial Bus Servo — Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration. Try it →
Sure, pull off the power shell and you will have a mini deans connector... I got a bunch of mini dean connectors on ebay for that very purpose.... Or you can solder any type of plug directly to the circuit board itself... Both will do a way with the power shell...
its very usefull to use an on/off swits to
thanks this should help a lot
If you can, you can also purchase mini-dean connectors at your favorite local hobby store.
