HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) — Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
Picture In Picture lag with tracking
Picture In Picture Lag With Tracking
Running ARC on a Windows mini PC mounted on a Roomba (connected via the Roomba OI serial to USB). I’m driving with the Roomba Movement Panel and want a rear/undercarriage view overlaid on the front camera while navigating tight spaces. I added two Camera Device controls: front is a Logitech C920 at 1280x720, rear is a cheap USB endoscope at 640x480. In the Picture In Picture skill, Destination = front camera, Source = rear camera (original image), overlay bottom-right at ~25% size. Visually it works, but when I also enable Face Tracking (or Object Tracking) on the destination front camera, I get 1-2 seconds of latency and occasional freezes until I stop Picture In Picture. If I switch the source to "processed image" or use the Swap option, the latency changes but the freeze still shows up intermittently.
I tried dropping both cameras to 640x480 @ 15 fps, and that reduces but doesn’t eliminate the stutter. I also want to script PiP on only while reversing, but starting/stopping it seems to momentarily stall the destination camera feed:
IF ($direction = "Reverse")
  ControlCommand("Picture In Picture", "Start")
ELSE
  ControlCommand("Picture In Picture", "Stop")
ENDIF
Questions I’m stuck on: does Picture In Picture feed the composed frame back into the destination Camera Device for other camera skills to consume, or do those skills still analyze the pre-overlay stream? If it’s the latter, is there a way to have tracking analyze the composed image without this latency penalty? Also, is there a recommended way (settings or ControlCommand sequence) to toggle Picture In Picture during direction changes on the Roomba without freezing the destination camera?
Roomba by iRobot
Synthiam ARCx turns iRobot Roomba into a drivable robot with scripts, sensors, browser control, and AI-ready robotics skills.
Controller Dependant
Servos ✕
ADC ✕
Digital ✕
Control Roomba/Create via ARC: drive, stream sensors, read encoders, configure COM/HW UART, and send pose to NMS for mapping/navigation.
Picture-in-picture camera overlay: superimpose one camera onto another; configure source/destination, position, size, border, processed frames, and swap
Yes - the destination camera skills are still analyzing the destination camera’s own stream, not a magically separate "post-overlay analysis feed."
What’s happening
With Picture In Picture:
  • The destination camera remains the render target
  • The overlay is drawn onto that camera’s output
  • Other camera skills attached to that destination camera may still be doing their own processing on that stream
  • If you enable tracking on that same destination camera, you’re stacking:
    • camera capture
    • tracking analysis
    • PiP compositing
    • redraws to the UI
That combination can absolutely create latency, stutter, and brief freezes, especially on a mini PC with two USB cameras.
Why it gets worse with tracking
Tracking skills like Face Tracking / Object Tracking are often CPU-heavy, and when PiP is also updating frames, ARC has to manage:
  • source camera frame copy
  • overlay scaling/blending
  • destination redraw
  • tracking analysis loops
Even if you switch the PiP source to processed image, you’re changing which image buffer is used, but you’re still adding processing overhead.
Does tracking analyze the composed PiP image?
Usually no, not in the way you’re expecting.
The destination camera’s tracking skill is not intended to use the PiP composite as its primary analysis source. PiP is mainly for display composition, not for feeding a "new" analyzed video pipeline.
If you want tracking to analyze a composed view, the better approach is to make a single camera/control chain that produces the final image, then put tracking on that output if the skill supports chaining that way. In practice, though, this is often where performance becomes the limiting factor.
Best practice for your setup
For a Roomba-mounted mini PC with two cameras, I’d recommend:
Option 1: Keep tracking on the front camera, keep PiP off during tracking
This is the most stable setup.
  • Front camera = tracking target
  • Rear camera = only enabled when needed
  • PiP = start only when you do not need tracking, or when the robot is reversing slowly
Option 2: Use PiP only during reverse
That’s a good idea, but don’t start/stop it inside a tight loop tied directly to $Direction every cycle. That can cause repeated start/stop churn and momentary stalls.
Instead, trigger PiP only when direction changes.
Here’s a simple ARC JavaScript pattern:
var lastDirection = getVar("$LastPiPDirection", "");
var currentDirection = getVar("$Direction", "");
if (currentDirection != lastDirection) {
  if (currentDirection == "Reverse") {
    controlCommand("Picture In Picture", "Start");
  } else {
    controlCommand("Picture In Picture", "Stop");
  setVar("$LastPiPDirection", currentDirection);
That avoids repeatedly issuing Start/Stop while the robot stays in the same direction.
Even better: use separate controls/logic
If you’re using direction changes from the Movement Panel, you can also manage PiP from a script or state machine that only reacts to transitions. That will reduce stalling.
Configuration tips to reduce lag
Try these:
  • Lower the front camera resolution if tracking doesn’t need 720p
  • Use one camera at a time for heavy processing
  • Avoid enabling processed image on both source and destination unless needed
  • Keep the overlay smaller
  • Reduce frame rate further if your USB bus is shared
  • Make sure both cameras are not competing on the same USB root hub if possible
In ARC UI
For each robot skill, open the kebab/hamburger menu on the top-right of the skill and check:
  • resolution
  • frame rate
  • processed/original image mode
  • tracking options
That’s where you’ll get the biggest performance gains.
If you want the smoothest driving experience:
  1. Front camera
    • tracking enabled
    • keep it as light as possible
  2. Rear camera
    • only used for PiP when reversing
  3. PiP
    • only start on reverse
    • stop when not reversing
    • only send the command on state change
One important note
If you’re using this for navigation in tight spaces, the ARC AI Assistant built into the script editor can help you quickly rewrite the direction-change logic and optimize the camera scripting right inside ARC: https://synthiam.com/Products/AI-Assistant
If you want, I can help you build a clean JavaScript state-change script for:
  • Reverse = PiP ON
  • Forward/Stop/Turn = PiP OFF
and make it only toggle once per direction change.
