Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
PS3 Remote Connectivity
Hello I am a 13 years old and new to the EZ-B concept. Along with other things, I need to ask a few questions relating to joystick connectivity. I was ready to buy a wireless controller for the EZ-B and then realised that I could use one of my wireless PS3 remotes. I plugged it it using the charger cord and started up the ARC. When opening the joystick panel it registered the PS3 remote. I don't know what to do from here on and am unable to make it register me pressing the buttons. I will be really grateful if anyone knows how to make it work.
Thanks
Liam Graham
Hi Liam, the first thing your going to try is to configure the remote. This is done by clicking "Config" on the Joystick window. In this window when you press a button on your controller a area in the box of buttons will light up. You can then enter commands like "Servo" to tell the EZB what to do when that button is pressed.
To get it to register movement, I believe all you need to do is place a movement window that best suits your robots method of movement. Ex: H-Bridge for DC motors, or Modified Servo.
Hope this helps!
TXTCLA55
Don't forget to check the Tutorial section. There is a video on how to configure the joystick. Or you can press the little Question Mark button on any control and it will bring up the tutorial.
So it does not make a difference if neither the button commands or the Movement Panel are highlighting? If not I am not sure what I am doing wrong. Would it make a difference that the buttons are symbols rather than numbers? Sorry if I am making myself sound like a complete idiot and wasting your time.
Thanks
Liam
Add the joystick control. The PS3 controller should be detected. If not, press the REFRESH button.
When you are in the Config screen for the joystick control, any buttons you press will be highlighted. I know the PS3 doesn't have numbers (it has symbols if i recall from my gaming friends). They are technically still numbered internally, you just see symbols on the buttons. When you press the button, the appropiate number will highlight.
You'll need a Movement Panel (either servo, hbridge, or roomba) that is controlled by the direction pad. Or you can specify servos to be controlled by the analog joystick.
There are no dumb questions dude:) ... It's awesome that you're 13 and building robots. I wish I had something like the EZ-B to work with when I was your age... I can't even imagine what kind of stuff you'll be building at my age!
I think there might be a connection problem with the remote because nothing seems to be working. I will keep persisting and see if I can crack it.
