Servo Pad icon Servo Pad — Drag mouse or finger as a virtual joystick to control pan/tilt x- and y-axis servos with configurable ports, limits, inversion, and backgrounds. Try it →
Open AI Chatgpt Not Speaking Full Paragraph But Mouth Does Continue.
Hello All and hope everyone is getting ready for the holiday and spread cheer.
Why when using OpenAI ChatGPT it will not speak the entire paragragh but the mouth does continue with paragragh?
Is this a OpenAI ChatGPT limitation?
Thank you.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
#9   — Edited
Issue found Azure text to speech limitation.
Use default Microsoft voice from computer no issues.
Thanks DJ for ther additional info.
Resolved.
@athena what robot skills are used in this conversation and what are the URLs to each one?
The robot skills mentioned in this conversation and their respective URLs are:
  1. EZ-B IoTiny by EZ-Robot: https://synthiam.com/Support/Hardware/EZ-B-IoTiny
  2. Bing Speech Recognition by Microsoft: https://synthiam.com/Support/Skills/Audio/Bing-Speech-Recognition?id=16209
  3. Watson Text To Speech by ptp: https://synthiam.com/Support/Skills/Audio/Watson-Text-To-Speech?id=19849
  4. OpenAI ChatGPT by OpenAI: https://synthiam.com/Support/Skills/Artificial-Intelligence/OpenAI-ChatGPT?id=21559
@athena what makes you think the watson text to speech is used in this question?
I apologize for the confusion. Upon reviewing the conversation, it appears that Watson Text To Speech was mentioned as part of the user's project setup but was not directly related to the issue being discussed. The primary focus of the issue was related to the Azure Text to Speech limitation, which was not initially tagged in the conversation. The relevant skills for the issue at hand are Bing Speech Recognition and OpenAI ChatGPT, as well as the Azure Text to Speech skill, which was identified as the source of the limitation. The URL for the Azure Text to Speech skill is: https://synthiam.com/Support/Skills/Audio/Azure-Text-To-Speech?id=21861.
